3 hours ago, doobin said:
For that application I’d ring up rather than cone split any day.
Easier and less mess.
all assuming you o my want to make the timber into small enough bits for the digger to handle.
Yeah just make small and manageable. Other week on a lawn, ringing up no no due to sawdust. Up coming job in a woodland at side of a path ok as can blow it all into under growth. I suppose 16" rings better than nowt. Just to break down to get the bugger away that's all. Get it dragged or lifted to tractor without it rolling off down a hill 😆
I had even wondered about using grapple instead of rotating grab as it opens wider I think, weighs a lot less but also has longer fingers / tines to go down and around timber to grab...?
I had wondered about breaking timber down at yard and chipping with a heizo but not gone further with that yet.
Edited by swinny
Screw splitter is good but comes down to type of wood and operator.  As far as boring down with saw, that takes away the point of having a seat and radio imo.  You learn to ready the timber and follow the grains.  Anything with knots takes longer, anything straight and clean just pops in half.  I doubt you would regret the purchase.
  • 4 weeks later...
On 09/07/2025 at 21:25, Stephen Blair said:
Digger making life easy today.
You changing that for a new model already? Or going back to running one machine across sites?
looks a great deal for someone in the arb trader 👍🏻
Edited by doobin
A friend of mine using my digger to shift the boulders put of the border and rip the stumps out on a commercial job that had to be done on a weekend  😮 😞
 Out yesterday doing some scrapes with the jcb. The TAB boom is so handy- lets you pull back in nice and tight to undercut the bracken rhizome cleanly against the blade. Then lift it up tight to build a bund behind you at a higher elevation.
