Could you fit it yourself? If you have the time and can, I don't see why you shouldn't save some money on the installation costs. If you do, you have keep in mind, that solid fuel stove installations done by a non-HETAS installer must be inspected by the local council’s 'Building Regulations Officer'. This could be costly and I suspect, that each council has its own pricing. You'd be wise to check first.
hi tgb thanks but i just havent got the time to spare to busy with log sales.
Where abouts are you?
You tried range moors or stove center ?
Hi thanks guys i will try them we are based near cullompton.
Try Elaine's stoves at Oakhampton. If there fitting is anything like as good as their knowledge on stoves you will be fine.
