Nothing new here, just going through the motions to help me continue to understand how wood grows.
Feel free to add your own comments/observations/images.
A basic premiss derived from various texts.......
Compressive wood = formation of reactive wood to gravity/wind force (made up on the underside of gymnosperm branches & trunks by the laying down of additional lignin in the woody cells to help push the weight against the implied force..
Tension wood = formation of reactive wood to gravity/wind force (made up on the upper side of angiosperm branches & trunks by the laying down of additional cellulose in the woody cells to help pull up the weight against the implied force.
  • Replies 27
Hi David,
Similar to your Oak shot above, I think, I have seen pronounced growth striations on the underside of heavily loaded branches on broadleaves indicating reactive growth (?) which I didn't understand.
Regarding the general premises of 'push' n 'pull', conifers n broadleaves respectively, in terms of remembering it someone, poss. on the forum, said broadleaves have biceps, i.e. tension pull like a bicep (not mine tho :biggrin:), n conifers have triceps, i.e. compression pull like a tricep (not mine either :lol:)
Anyway enough waffle from me, clearly I need to go back to 'arb' school.
Thanks as ever for your informative posts, racks up my CPD every time :thumbup1:
Cheers..
Paul
Hi David,
Cheers..
Paul
This is a good way to remember it!! :thumbup1: I find these little phrases helpful.
Any shots?
afraid not but they are very similar to the branches in your shots ripple wise.
from memory they are 24"dbh+ and very straight and tall. no lean that I can remember hence why I wondered if its just the wind that can do that.
they are relative close forest grown. they look like a cylinder of ripple!!!
Having said the above, trees don't always play strictly by the 'rules'.
I think we can draw a distinction between normal (homogenous?) wood that happens to be growing more rapidly to cope with applied forces and structurally specialised wood doing the same. It might seem like a semantic trick but just as a rock can function as a fairly serviceable hammer without being a 'hammer' - not all wood resisting compression is compression wood (and I imagine the same applies to tension wood).
I imagine that all trees will add wood where the cambium detects uneven forces - if they are adapted to produce specific types of wood, then they will use those. Trouble is, you need a microscope to see the difference.
