Dean, What do you mean Anti-cut shroud?:confused1:Do you or Bob have any pictures? I'm intrigued!!:001_smile: Cheers, Tom
i do have a load of photos of this set up but not with me sorry
which i am a big fan of and think its safer in most situations
it,s basically an SIP slong which you get a dyneema 120 normal climbing sling then half it and larks foot each end
which means if you did cut one you would hopefully not deck out
then the slong is basically wrapped round and velcro hold it together and the slong has a couple of layers of kevlar in it which also helps
then clip one end to harness and one end to friction device and the first bit is protected
will post some pictures upon my return as i am presently sat on balcony on holiday on arbtalk much to my wife,s disgust
hope that helped for now
  • Replies 43
You told me your lass did as you told her and that you wear the trousers in your house.. :001_tongue:
Cheers Bobs
Nice one Bob. Cheers for that. Enjoy the rest of your Holiday. It's nice to know that the Arbtalk addiction still effects abroad!!!
  • 4 weeks later...
Finally got round to the photos of the bridge setup we use at work for the lock jack. The credit is to a guy in work but it is a spliced rope around 3m with a Blakes. The other shots are of the system i use in work based on drews model.
