  • Replies 20
is it best to get my oak, and sweet chestnut inside, before i mill it in november time?
or leave it out side in the yard?
Makes no odds really. I'd leave it outside as I would want to stop it drying through the cut ends any more than necessary and it will stay a bit wetter that way.
Alec
I'm putting off milling now until Oct/Nov time...
Milling and drying wood is something that takes a few years to get a feel for. Initially I would not worry too much about getting all details exactly right first time. Look to build your knowledge over years rather than trying to hit the ground running.
But when you come to mill try and be tidy. Get your planks the same thickness and when you come to stack and stick it do it neatly with even stickers.
:001_smile:
what size saw do i need?
i have got a 372xp is that big enough? or
do i need a new toy?:thumbup:
what size could the 372 run / cut
If you're using an Alaskan you'll lose 6" of bar length and i've got a feeling the 372 should only be running 24" bar so looking at milling 18" - any more and it's off to the toy shop :biggrin:
  • 1 month later...
I like stickers about an inch wide by say 5/8" thick. I place them every 2' or thereabouts and place the first set about 1' in from the end. I wouldn't worry about painting the ends at this point - if you were going to do this it would be better while it was still in the round.
Alec
ps - we need pictures!
