Hi all, I've got some speedlining to do in a week its been a couple of years since the advanced course and I can't remember which is the best shortening knot to fix up the middle pulley with, theres gonna be loads of tying and untying so the best ideas would be simple. I'm not sure if a sheepshank does it ok?
Sheepshank would work I think as it is a shortening knot but I don't get what you mean about the middle pulley?
In fact I don't know what you mean at all, but it is morning and I have a headache.
The middle pulley is where the tensioning takes place and the rope is fed through before being tied off, also where the section zipped out stops.
Please take some pictures when you do the speedline job, I would like to see your set up.
The words 'sheepshank' and 'speedline' should not be associated. The sheepshank is one of the worst knots ever invented and when it comes to tree rigging operations involving lowering loads or speedline a sheepshank has no place whatsoever. In fact the sheepshank has no place in treework and I doubt you'd find any serious treeworker that disagreed. It could be used in camping though - for guying up a tent.
Re Speedline Set-up
These might help you -
http://www.treebuzz.com/pdf/speedline_variations_1.pdf
http://www.treebuzz.com/pdf/speedline_variations2.pdf
Re Speedline Set-up
http://www.animatedknots.com/sheepshank/index.php
Shows and tells you all about the sheepshank! Couldnt agree more...
To secure a tarp or raise a tent its reasonable safe but for other purposes....NOT!
the knot I was using before wasnt a sheepshank but like it and tied off twice at the top and bottom? I dunno can't really remember. Prussik sounds like a simple idea that can allow you to slacken the speedline easily, will give it a go - don't know if the force of the piece hitting it will cause problems though?Thanks for the info guys.
