afternoon all, been reading and lurking for some time, did,nt ask for out in me first post lol, (but now I am)
I was going to make a hydraulic log splitter, but ive got all the bits in me spare part bins to make a screw type splitter, either petrol ingine or electric motor.
the one thing im after is the screw threaded cone, does anyone know where I can purchase one cheaper than 80
nicker?? or does anyone have a old one kicking about they want to part with??
don't really want to throw 80 nicker away in case my idea don't work.
cheers, pete.
  • Replies 20
cheers, pete.
Your idea will work providing you don't stint on the grunt to turn it.You need at least 25hp minimum 30 + preferably . Its the torque you need not rpms and to get big torque you need big cubes ( relatively ) Anything less and it will stall on the first snotty log and you will wast loadsa time having to cut it off the cone . Believe me !
Don't think they that dodgy once you get used to the forces involved and the potential to get whacked ! Certainly quicker than most hydraulic ones I would say ( I have both )
Pete! - don't bother :thumbdown:
Unless you're going to do it properly trying to run one from a petrol engine - and worse an electric motor - is not worth the effort.
You need upwards of 15hp to stand any chance of splitting wood suitable for a fire or woodburner - and it needs to rotate in a controlled manner up to approx 450rpm.
And your £80 cone? - most of the eastern european ones we've seen aren't worth a light long term.
Save your time and money let alone your limbs if you cobble something together.
15hp is not enough . Godda be twice that ( re my answer second post )
HI STUBBY your right mate when first started off i had a pto cone splitter i had it on my mf135 it was a good old splitter just keep your eye on things :blushing:thanks jon :thumbup:
cheers for the replys, I have a various ingines about and a few reduction boxes, im far from stupid, so would not make "cobble" something together that I would injure myself with.
I enjoy making my own kit as I know it will do what I want it to do, and it would be a sight better than I could buy.
just wanted to know about splitting cones??
thanks.
yep on the back of a tractor there ok..
i filled a 40ft container with splits in 2 days alone and only got my knuckles rapped a couple of times.:blushing:..altho them cones on a tractor willl snap your hand off there cheap to set up.
We've sold a number of Hycracks to people with Iseki and John Deere compacts and have had good feedback - and perhaps most people's grey fergies when knackered pump out much less than 20hp at the pto.
However I agree with you guys that 30+ is ideal. We run ours either on a 50hp Kubota or our 90hp MF4345.
The real reason for my post was in response to my shiver when I think of people 'cobbling' together machines that could bite them - and badly
Edit: Pete23 - just seen your later post. No offence meant re cobbling - it's just that we've seen some shocking stuff brought into us for 'spares' when the eastern european cones and bearings are knackered. Do it properly, with the right hp and I agree with Stubby that a cone splitter is a good tool
Edited by LoadhandlerUK
