Stihl 026 advice
Stephen Blair
New 026's ????:confused1: They are 1 turn on each screw
If its an MS260, or MS261 then 3/4 on the H and 1 turn on the L is correct if the limiters are on.
The non adjustable pump on the MS260 Farmboss does not have a drive arm, but also has a different drum to the std MS260 which has an adjustable oil pump driven by an arm.
There is a conversion kit available to upgrade to an adjustable pump.
  • Replies 27
I have literally just re run in my 14 yr old 026 after having a new piston and a few other bits and bobs to go with it. Cost about £250.
It's like a new saw now and would prefer that to a new 261 which 'might' go wrong. The 026 NEVER went wrong in 12.5 yrs and then just started being a bit unreliable. So it got fixed.
Pleased to hear that having given the mechanic the go ahead. Just hoping the barrel isn't too far gone.
Sent using Arbtalk Mobile App
Because thats how we dealers work:sneaky2:
And I thought you would be a tea and cake man:lol:
I didn't mean anything by that, you do a much wider of variety of kit and I specialise in one type specifically - I know enough about business overhead from my manufacturing days - finished us off in the end:thumbdown:
Hi, usual me threw away the handbooks when the saws arrived last hear:001_rolleyes:
1, what's the hi and low settings? There are no numbers beside the screw holes:confused1:
2. The oiler, the clutch cover has the little notch out it, but there isn't a little spindle thing to turn, and the saw is oiling ok:confused1:
Is this a new design but use up a huge box of older covers!!!
Am I right in thinking they did this years ago and then went back to the turns thing.
Cheers:001_smile:
I still have my instruction manual for my 026 (as well as the saw which is still fine) which I bought 20 yrs ago. I could scan the relevant pages if you want provided you don't mind it in French?
