new pot and barrel
Treegeek
I would check the cylinder and try to see how it cleans up first. If you can save its always the best way to go.
Aftermarket pistons if you buy the likes of meteor, episan or hyway will do a good job.
Cylinder wise meteor prob make them if you have to go down that route.
EDIT... doesn't appear meteor do cylinders for the above
Cylinders - Meteor Piston
Edited by wisecobandit
If you wanted a second opinion from me then read the above....again:thumbup:
My experience of seized 346XPs is that they do score the cylinder but you may be lucky. I do have a nearly new OEM kit but would need a good offer to part with it:blushing:
If you go Chinese - make sure the cylinder has closed transfers as the originnal does! If you go this route , fit OEM or Caber ring to the piston!
