sharpening a sawbench blade
forestgough
Theres is a vid on utube ive seen. Will have a quick look a mo but it may help it may not.
[ame=http://www.youtube.com/watch?v=jKKcyKxu7aQ]Sharpening a circular saw for cutting firewood: part one - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=4xA6TFE9cI4]Sharpening a circular saw for cutting firewood : part 2. - YouTube[/ame]
Take it to or send it to a saw doctor. They have the correct equipment and can get all the angles right. You can never replicate their accuracy by doing it by hand.
I agree to send it away to have it re tensioned and gulleted but touching up the top face only with a flat file is necessary between major sharpening.
+1 for what it takes to do one its as cheap to get a saw doctor to sharpen and balance it for you thats what you need is it balanced a unbalanced saw can become a dangerous blade which can cause serious damage if it breaks and fly's off.
I used to tickle my saw bench blade with a mill saw file and had the tool to put a bit of kerf into it too.
It would get a proper tension and gullet from a local saw doctor every few years and I would be able to follow his angles for a long time then.
If you do it well, then the rotational balance remains more or less the same - take off as much with the left as the right, just like a chainsaw chain!
