Well theres a slightly cleaner example of the same trailer on ebay at £1000, other twin axil versions are around 1200 - 2200. I would say clean it up a little and try it for £995?
At the end of the day though its only worth what someone will pay for it.
Age make & payload would influence the value to some extent, failing that I would think between £700 to a grand tops, (just because the one on ebay just started does not mean it will attract bids).
If yours is a year old IW or Indespension, with a good payload it could fetch more.
When you work out what its worth I may be interested in buying it. Depends on age and condition. It is one of the smaller ones so will only carry around a tonne. Is it shutter or ramp door.
It's got double rear doors with after market locks fitted , just had a full service with ifor Williams and 2 brand new wheels and tyers as the others were not rated ones , pm me if your intersted :)
