H14 (PTO) for me too - I like the way you can control the speed by selecting the correct gear and you feel in control. Mine also feels bulletproof. The only down side I can think of is that the bearings on the pto shaft are a little hard to come by - my local prop shaft company did the business though when it needed rebuilding.
Best of luck
  • Replies 22
if your expecting the winch to do any hard work, then a hydraulic or PTO driven one is a must, the duty cycle on even the best electric ones is awfull, and the warmer the motor gets, the more current they draw for the same pull, ( I used to fit the Electric ones on fire engines and these were electronicly de-rated to 3 tonnes for this reason), even the cheapy hydraulic ones will run at a constant pull all day, just watch the fluid temps, and your PTO ones, well how good's your gearbox, depending on your base vehicle, there are a multitude of fitting kits and systems out there, just depends on the depth of your pockets, and your level of "engineering" ability as to which way you go (running a mog I'm spoiled, one werner on a TPL mount , and two cheapy ones, one rigged to fit on the hiab, and one for a front or rear mount off the tow hitch points, I wouldnt go back to electric for any serious work ). good luck with what ever way you choose to go
Aren't they american?
Don't get me wrong, the yanks make some great stuff.
Just none with moving parts.
Except the Zippo and lets face it, that's only 2.
Oh the irony, its been a while since the spitfire........
Warns are find winches
Edited by Timbermcpherson
