hi all, need some advice in knowing whether or not we need our chimney swept.
it was put in a couple of years ago including a lining and is only a small closed logburner with about 1ft3 of space inside.
its had two winters use and i would like to know if it needs to be done yearly, never or whenever really...
any help very much appreciated...
thanks
Steve
I've always been told to do it yearly.
I think its mostly down to what you burn aswell.
Mine gets done yearly regardless. Would rather that than the dreaded chimney fire. Piece of mind really.
Got a set of rods with a disc a worm for the drains and a brush or sweep for chimney 20 yrs back I put em up every autumn before I start log burner up never had a problem. If you don't mind getting mucky DIY , as for the drains that really is a mucky business!
Same as you . Do it myself one a year , now in fact !
Harry mate just make sure you give it a good going over till nothing's coming down , I've also got a open fire yrs back made the fatal mistake of not covering opening , bloody place looked like a bomb had gone off ,missus threatened divorce , white staffy went black I got a cough!.
