Wow. What is going on there?? Someone please explain to me how stuff like that happens?:confused1:
I'm guessing (from a relatively limited Mattheck understanding) that the branch is under serious lateral & vertical torsional stress & that it's putting on these cross ribs (at points of weaness - notches) to acheive optimal mechanical tension along its length.
ain't nature great. :001_cool:
I agree sean I'd love to have the chance to have a butchers inside.
Edited by Monkey-D
I will have to dig the one out I found in Hatfield forest, not as pronounced as this but a longer thinner branch doing exactly the same, hornbeams, ash and Birch seem the most prone to this type of adaptation.
Its all to do with the stress on a notch shear plane, always 45degree angles, ive wanted to see such a good example for a long, long time, its got it all there, and a lovely notch.
The stresses on this limb are extreme because the origional lead died, and a sub order lateral has taken over and gone of at almost 90 deg and extended so far. the torsional moments on that limb must be immense during gusts!
love it.
Along with what David said it looks as if some secondary limb absorption may have taken place.
Dave
Sorry to ask, what do you mean by this?
If you look at the starting point, it seems possible that there were multiple limbs in the past that grafted/merged with the main stem.
Dave
