Japanese knotweed
Rich W
You can't have pa6 without pa1 as its the foundation module for all other units. You will be mixing and doing minimal calibration
that is how i thought it was as i had to do both as for stem injection did not know it came ready mixed i thought you had to fill the cartridge up then inject i stand corrected
You cannot get PA6 without PA1. PA1 is the module that covers handling of pesticides, PPE, duty of care, record keeping etc, etc.
While on the subject of splitting hairs of course:001_rolleyes:
EDIT; I wonder if anyone knows if PA2 would cover direct stem injection?:confused1:
No, PA2 wouldn't cover it, PA6 reads on my cert, atomised sprayers and application with minimal calibration (stump painting in other words)
Sent using Arbtalk Mobile App
So if the packs that we use come in sealed units and every time you pull the trigger on the gun the correct amount is injected? never get to mix chemical or pour it...
Same as eco plugs? what pesticides cert do you need to use these ? as no mixing or calibrating???
