Cheers guys
Got it pretty good - gave it a good dunking in some hot ish water with plenty of veg oil. Then a wash with hot water & wash up liquid, then a good blast with the hose on jet. Came out nicely apart from a small section which had been saturated when left in the tree overnight, better than it was but still hard in the core...
Next time do the same again but ditch the veg oil and replace with non bio. All you have done in make the washing liquid work hard to disperse and break down the oil content in the wash....you don't need veg oil
Any reason why butter rather than something veg based like sunflower oil or veg based lard / fat? Saw another thread suggesting mayonaisse which would imply its the fat doing the job. Sunflower oil would be less smelly than butter / mayo.
Anyone have a LOLER issue with butter etc on rope?
Cheers
Check with your own LOLER Assessor for individual items, But ART do recommend it on some of their gear, it's in their manuals.
I have found a faboluos product, Savon Noir Liquide a l'huile d'olive- Marius Fabre only 8€ pro litre. After put the rope in light warm water I use pure Savon Noir massaging a little to get the soap into the fibers and then brush the rope with a tool I made miself with 3 little brushes and 2 plastic cans. Enjoy it.
Sounds a bit sexual;)
I was always told for pine resin is that if you get it on your equipment or hands in the tree, as soon as you get down kick up the dry mud at the bottom of the tree (make sure it's dry) rub it on the resin thouroughly and when you get home will just rinse off and it's worked for me :)
  • 4 years later...
