Ho often do you change the oil in your bogies TCD? has a seal gone to let lots of nasty stuff in?
Not often enough! :blushing:
Should be 1000 hours or 12 months... Old bogies probably let moisture in more easily. Missing o-ring from one of the drain plugs - completely oil tight though.
Further to some of my previous posts re oil: I was talking rubbish sorry. Hytran applies to the international skid unit and in the case of the 578 is therefore all the transmission and gearbox plus the hydraulics / crane etc. In the 678, I guess you want it just for the transmission but the crane has a seperate tank and I'd imagine 46 would do. Still EP90 for the rear diff and bogies.
Query - have you got 500 or 600 tyres on yours?
Thanks.
Thanks, that seems to make sense to what I have seen and spoken to people about.
Running 600's on ours and after some bandtracks if anyone has some for sale?
Also have a set of tracks for a bruunett running 500's if any one is interested in them?
Is yours fitted with a center brake that holds the transmission, located behind the cab? if so do you have any ideas if it a closed system or somehow linked with the transmission?
You couldn't have asked that last question at a better time! Coincidence or what!
500's on mine - got some lovely tracks to fit - see pics several pages back - well happy with them; got chains too. All nearly NOS for scrap money. Richard Court might well have 600 tracks. Remember - don't run them too tight! Bruunett bogies no likey!
Right the centre brake - I've just stripped and serviced mine and ordered new brake linings from OHBC (part of MICO); great co to deal with but very long-winded ordering process and parts come from Mexico once a month! Speak to Sharon Sheppard at:
Off Highway Brakes & Controls Ltd
Company Registered No: 2328874
VAT: GB488090120
Phone: +44(0)1386 - 555562
Fax: +44(0)1386 - 553955
E-Mail: [email protected]
Web: Off Highway Brakes and Controls Ltd
MICO: http://www.mico.com
The Centre Brake is a "Spring Apply - Hydraulic Release" thus a parking and emergency brake in the absense of brake hydraulic pressure. You most likely have a MICO 530 series brake as per here: (excellent video).
[ame]
[/ame]
I'm not familiar with a 678 cab console but assume you have a brake pressure gauge? Thus assuming you have brake pressure, the handbrake by cab door works ok? The linings are notorious for wearing out quickly tho.
When the handbrake is "off", the cable from it to the brake valve operates to allow hydraulic brake pressure (under the cab (nearside middle)) to force the spring pack in the disc brake at the back of the cab; you should have a large brake disc. When you apply the handbrake, the hydraulic pressure is cut off and the spring pack presses the linings against the disc, which is connected to the prop-shaft. The foot brake operates the multi-plate wet brakes in the transmission - this is completely seperate to the parking brake.
You will notice 2 x brake cylinders in the engine bay - under the cab front window - one for each.
The brake disc slides on a splined section of the prop-shaft to allow for brake lining wear as the caliper sits on a overhead pin which allows some float; it rattles like a cowbell if the linings fall out!
Here are the pics of mine...
Hope this helps. My caliper is obsolete but the new one replaces it as-is; does yours have the 4 mounting holes in the bracket?
Parts required are Lining Kit #20-060-021
02-530-600 has become 02-530-628.
If you need parts, ring asap for the June order!
  • 1 month later...
few pictures from where we have been pulling out from this week, really wet as you can see, But its pretty much all out now
Can anyone recommend a place to get new internals for the joysticks on the 678 as they are starting to become a but worn, we have cleaned and stripped them but I think a rebuild will be in order soon and I have a few weeks break for it coming up
Its not the ground conditions that are your problem Dave, its the lack of traction aids thats making it hard going, put some chains on her and she'll be flying out of there fully loaded.
Tell me about it, looking all over for some at the minute, seem to be rare a rocking horse poo, and cant really justify the £7k for a new set.
So if anyone has a set of 600 tracks or chains kicking around unused I would be very interested
