Says "very little use" but the paint missing from the bar says other wise.
With the chain on backwards it would of course get very little use tho......
  • Replies 21
Popular Days
Ok so lets run through it.
It's a DCS7300. It says on the sticker with the barcode on the handle.
It is used but it is in a good condition.
We don't know it works perfectly but it must be easy to start.
18" bar is right as its 45cm on the bottom and that's 18 inches. And the chain must be sharp as its on backwards. But does look dirty so hasn't been sharpened recently.
It is clean. Not so sure on the use by the wear on bar.
Powerfull. Maybe....
Not a grand when new that's for sure. Not on a 2002 dated saw.
So the only thing is the 73cc/79cc miss print ?
Yes title says 73cc but the description says 79cc.
But the op is referring to pictures and discription.
Only thing I can see is the chains is on backwards and its blunt.
But it is semi chisel. And it's the right chain for that bar. And the bar is the right size...
