lot of firms are putting t groundsmen through chapter 8
i been told if you take this course and have the tickets and any does go wrong ie if you never use the right cones or not enough signs you can take the full wrap, just be carefull if you are ask to take this course and try and get some legal advice to see were you do stand on this
  • Replies 28
If you work on the highway, using signs, cones etc; you should have it anyway.
thats right, but been told by a solicator if you have chapter 8 you are putting your head on the block if anything does go wrong
got 4 branches to remove for bus route it will take longer for me to set up than it will to climb the 1,st tree remove 3,branches then swing across & remove 1 branch from 2,nd tree might just do what tha l/a do 4 cones 1 sign ?:confused1:
An interesting slant there my friend
If your employer is paying for the course & is paying your wages to attend the course to give you knowledge & accreditation that enables YOU to reasonably & dilegently perform your duties for your & others safety
Then be grateful Accept the course & then carry out your duties within the guidance that you have been trained & then you wont have a problem
Or you could refuse the course ,which is a resonable request & promptly pick up your P45
Your choice , ME Id be thankful to have a job with a good employer .
If you have the '8' and you set everything out correctly you have nothing to worry about (if something goes wrong.)
If you don’t have the '8' and your working on the highway and something does go wrong you'll be getting to know a lot of solicitors very well!
firm i work for just put 6 young blokes through this course a ONE DAY COUSRE that give them all this resonabitly when they get there tickets and its there head that will roll, it funny the older guys and wiser all have refuse to do it.
Wiser???
They refused a course and you call them wise!? Not a description that springs to my mind..lol
Bet they never get offered another course! Well-done you young guys! :001_smile:
By going on the course you are increasing your knowledge of traffic management and making a safer environment for staff and the public.
Your are also making your cv more desireable for furture employers!
