i have a job to poss make a pair of gates for a churchyard. thought it would look good as most churchyards have yews. done very little in this way. what size yew would i need to get a 3"x3" post and will yew cut ok.
In my experience, mills really nicely. A good stable wood. I milled some a couple of years ago with my Alaskan, and if I get this right, you should be able to see the thread here
http://http://arbtalk.co.uk/forum/milling-forum/30231-milling-yew.html
Nearly 2 years ago now and ready to use, no cracking and no warping to speak of. Was stored outside with stickers of 1.5", and ratchet strapped together around the whole milled tree to stop any potential warp.
Beautiful wood to work with, you get the 'wow' factor every time you peel a board off and see what colours and grains are beneath.
For a 3"x3" post you want to be looking at around 6" across I'm guessing as a minimum, so you can square it off
Sounds a great idea to make church gates with it, look forward to seeing some pictures!
so it will need to dry out for some time before i can use it. pay to look for some seasoned stuff and use that.if i do do it will put some before and after. looking at doing it just to see the finished job. even if it turns out a freebe. just for the satisfaction of doing it
Shame, we have just milled a massive yew but planked it into 2" and 1.5" it looks beautiful but is green. Pictures are on our Facebook page
Welcome to Copford Farm Sawmill, oak, green, seasoned, beams, saw mill, Horam, Heathfield, East Sussex, BS5756, TRADA, timber grading, graded oak, grade, TH1, TH2, THA, THB, Alex Gingell, Harry Gingell, sustainable, restoration, timber supplies, supp
Follow us on Facebook too
hope thats not my Yew Harry!
simon
