hello everyone im looking for some advice about chainsaw milling bog oak its been out of the ground about 6 years but not undercover can it b done
May be an idea to give it a monster pressure wash before you start as the outside will be well and truly impregnated with grit!
Can you put some pics up when you have a go at it?
:001_smile:
if i can get it out of the field i will if it ever stops raining . Its 30" wide going down to about 18" and about 12m long im not sure how thick to make the slabs ive been told it can fall apart if to thin when dried
That should have been "milled in the fens", it was felled by nature about 4000 years ago :lol:
Here is the thread on the bog oak referred to above, the project is a masterclass in how it should be done.
http://arbtalk.co.uk/forum/milling-forum/48467-huge-tree-milled-fens.html
These guys specialise in bog oak and if the log is sound they might be the best people to mill and kiln it for you. Or at least give the advice and or contacts that you need.
012.jpg.184a2356bb5cff527785da44133f83c6.jpg[/ATTACH][/ATTACH][/ATTACH][/ATTACH]
Thanks for all your advice ive cross cut it and taken a few pics for u to look at to see what u think
