Starter
jackmayo
I really want to start climbing trees with ropes and was wondering what equipment I need to buy and if a can buy it second hand for around 100 quid.
I can buy rock a rock climbing harness, carabinier, belay device and 30m of rope for £90.
What should I do?
Thanks
Jack
  • Replies 34
What should I do?
Thanks
Jack
I would avoid second hand kit. And avoid rock climbing gear. It's not fit for purpose and can't make life easy. I know people have used it in the past and got on with it but that's my 2pence worth.
An inexpensive way in Jack is a harness like a Petzl Avao or Navaho, a hitch climber kit and a plain ended rope, splices add money.
Navaho harness...
Petzl Navaho Sit climbing harness | F R Jones and Son
Aeris is pretty cheap and seems to be OK for both SRT & DDRT, not to mention mechanicals, so a good all round rope....
Marlow Aeris blue & yellow 11mm 1 splice | F R Jones and Son
And hitch climber kit.... [8mm cord on 11mm rope]
HitchClimber Friction Hitch System
You'll need a lanyard, which you can make up yourself cheap enough with a couple of lengths of cord and 2 biners, plus a pulley if you're so inclined and you'll want a cambium saver, but there's no reason why you couldn't make up an adjustable one yourself as well, or even a pulley saver for a few quid, and a throwline is always handy....
Navaho harness...
Why complicate things, cheap harness, 4 carabiners 2 prusicks and a cheap rope.
A perfectly good vt setup can be purchased for less than the price of a hitchclimber.The treemagineers must be laughing their way to the bank with all the advertising from you guys who seem to think its the only setup
Sent using Arbtalk Mobile App
:thumbup:
Only issue I see with that is that the Navaho harness with it's single ventral ring makes it a bit tight with 2 carabiners, I really like the single attachment point arrangement of the hc or sky walker pulley...
You don't need 2 carabiners, a dmm boa is large enough
The other point is that he is a beginner, start at the beginning, learn the basics and advance when ability allows, he doesn't have to be a srtwpblahblahblah convert from the word go
Edited by John Shutler
