Hey guys,
I dont know whats going on with my chainsaw. Ive been cutting small trees and brush and the chain keeps falling off. I have it a little tighter than normal to try to combat it, but still happens. I put a new chain on it today (but accidently cut against a brick for a few seconds). It is falling off the tip and around the wheel part that makes it turn. its a ms290 stihl, only 7 months old. could it be the dull chain? any advice would be appreciated. thank you very much
I would take a look at the tensioning screw may be worn/stripped.
Or the chain is worn and stretched and is also at the limit of the tensioning screw and so once the chain warms up all the tension is lost.
All I can think of. I've been there and think it is the latter.
If you didn't have the problem before the new chain then the new chain must be the problem
Compare it to your old one as you may have a 325 and 3/8 mismatch somewhere which would lead to them coming off
Sent using Arbtalk Mobile App
Take a look along the bar groove, make sure there are no small twigs along it, run a groove cleaner through it. Have you nipped/twisted the bar slightly, that may cause the chain to jump up and off?
check that the nose sprocket of the bar hasn't started to split, we had a similar problem with our pole saw a few weeks ago, and that was the problem.
Check the bar isnt bent - take it off and put a straight edge against it!
Is the oiler working OK - lack of oil can make the chain tighten and eventually come off - first sign is overheating and a brown coloured chain that is stiff.
Do you put a wood chock under the bar tip and push the saw downwards when tightening the chain - it pretensions it and stops the bar moving on the first cut.
Are you doing the bar nuts up tight enough?
Larger Stihls use 1.6mm gauge - are you sure your chain is correct and not wishing to teach you to suck eggs but make sure the chain is the right pitch - 0.325 and 3/8" are the most common. Make sure you have the right one.....I have seen a 3/8th on a 0.325 sprocket before:001_rolleyes:
If your bar rails are worn down you can get a situation where the drive tangs don't sit in the groove correctly . If you can rock the chain from side to side ( a significant amount ) after tensioning the the bar at best needs the rail dressing and worst its shot .
Read more
