Solarez Resin tips please
Paul Smith
Paul
The company Trylon used to provide written guidance about embedding items in resin and other related topics. I looked at their website but there is nothing to download, but maybe they can send something out if you contact them by e-mail. From memory, you need to build the resin up in layers, but don't let each layer fully set before adding the next. Try to catch it at the stage where it has just 'gelled', i.e. a bit rubbery. Re the bubbles, my recollection is that you need to let the resin stand in the mixing pot for a while so that the bubbles caused by mixing rise to the top before pouring it.
It's possible to finish resin to a really smooth/glassy surface if you use progressively finer wet and dry abrasive paper then finish with a burnishing cream. T-cut which is sold to remove fine scratches from paint on car bodywork might even work.
Andrew
not sure about solarez but ive used loads of clear resin to mount things in stick handles, fishing flies etc, i build up around the item to be filled with plastecine and do it in one pour, whan its hard i take the excess off with a powerfile then finer and finer sand paper until im down to 1500 wet and dry, and then T cut, comes up like glass.
