Has anybody had a trouble of it ripping up the rope fibres as it goes through the links? On the side closest to where they krab attachment points are?
Sent using Arbtalk Mobile App for iPhone
  • Replies 430
Not on my 12mm Yale it all seems rope friendly so far.
Optimal climbing weight??? What weight to the say is the limit?? :confused1:
It was discussed at length at the final decision was 11 stone.
Not sure i agree with that. If your hand is not on the minter. The zig zag will take the load. Just like the wrench, your weight will transfer back and forth. But if you were to fall without your brake hand below the device, you will shock load the zig zag.
Very good point, hadn't thought of that:thumbup:
ZZ is aggressive on your ropes tho, as a hitch takes the brunt but the with the ZZ the rope does as it steel. i can feel it on my ropes after a few days use. Dunno about ripping up the rope fibres tho, that sounds like you got a sharp edge somewhere, i double check that ay.
Poison ivy by anychance ?
no mate its tachyon. poison ivy been doing it then?
Not that I no of its just when I use to run pi on a sj it shredded up alot at first but as soon as I switched to velocity it was fine,is your rope new?
You using a pulley saver?
