  • Replies 43
eee, don't like the look of that! A ring would be much better. I reckon it would depend on line angles and bark smoothness, so prob a case of judgement on each tree.
i tend to use a dmm ring as it seems to bight better and releases easily. I've retrieved this setup form about 5 natural redirects. Only hard thing is getting the alpine to move but once it starts it comes out easily enough.
You still snowed in Benn??
Yeah when retrieving rope on rope it's hard to retrieve through more than one redirect as the rope on rope causes a lot of friction, Ian flatters showed me a cool trick with just a aluminium ring, just put your line through the ring and around desired anchor point then tie direct to the ring leave a long tale to what ever length you require or add a second rope or throw line to retrieve, the ring takes a lot of the friction away making retrieval real smooth
Hope this helps mate
Read more
