  • Replies 20
just gathering the bits to make one as they are not available over here due to not being ce marked. Got my flywheels and engine. Trying to get a good price on the rack and pinion. The other one similar is the DR Rapidfire.
Here is a good clip of a home made one but maybe a little over complicated?
[ame=http://www.youtube.com/watch?v=YXl4FZEqw6c]Kinetic baler Flywheel log splitter. Splitfire Supersplit - YouTube[/ame]
There is more to it than meets the eye when it comes to but that life!!
way to expensive to produce compared to hydraulic
Surely much cheaper to produce? No pump, no spool valve, no ram, all of which require precision expensive machining. Then a tiddly little mower engine ( 6 hp in the DR model) instead of >11hp for hydraulic models.
Flywheels could done even cheaper by using car wheels filled with concrete & balanced with wheel weights or lead in pockets cast into the concrete.
Only thing to wear is a cheap linear rack - looks like a brilliant idea to me.
there are plenty of flywheels about and much more balanced than some of the above. i'm using 2 rollers out of a old roller mill for cattle feed. came with bearings and shafts for next to nowt.
