Tried them a few times but given up we dont get enough sun to get a decent crop, best i got was about 4" diameter but it tasted delicious, might give them another go ........ thats summer knackered now :lol:
  • Replies 361
Hello,
We have a fairly decent veg patch, we grow lettuce, leeks, parsnips, butternut squash, peas, broad beans, harricot vert & jaune, pomme de terre - potatoes & courgettes, tomatoes. We also have a lot of plum, some apple & pear trees. Our climate is well suited for growing it does get very hot and dry in summer but the soil seems to hold the water well.
We dont buy much seed & try to avoid F1 hybids unless there is no alternative, I think preserving seed stock is a really good idea, GM & F1 would eventually kill it off. We allow plants to seed & dry them out then store for next year, some seed such as lettuce we just throw it on the ground, as opposed to fiddling around with compost & pots, then we prick out the strongest & plant them in rows.
Its all a matter of experimenting to see what grows best, last year we tried peas for the first time which grew 2 metres high with thousands so were still on the pea soup (parp!) Tomatoes were better the previous year, but our neighbours let us help ourselves when they were away for a week because if you dont pick them they stop producing. So if you can swap your surplus with a friend or neighbour it helps when one crop fails.
We also try and plant by the moon, because this affects the water table & hence the success of the plants, yes, I don't mind if you laugh, but it really works. We don't use chemicals apart from Bordeaux mix which is organic on the trees.
So its a matter of experimenting, theres nothing like it for taste et bon chance et bon courage!
N
GM really worries me, if we dont start turning against it in a radical way its going to be far worse than any other man made issue.:thumbdown:
Sadly I feel that once again, the genie is already out of the bottle on that one.
With 7 billion & counting, the agri companies will eventually back all governments worldwide into a corner to agree to the use of GM simply to be able to feed the worlds population (est. 10bn by 2050).
Even though they estimate that 50% of the all the food produced in the world annually is lost/wasted/thrown away even before it sees a plate!
Almost half of the world's food thrown away, report finds | Environment | guardian.co.uk
listen, this BS myth there is no way to feed the world without GM is perpetuated by the GM corps themselves, ifyou do the research yoll find that GM is far from the promise, and actualy more an agenda for population control and profits.
This makes some interesting reading
failure-to-yield.pdf
