New replacement saw arrived late afternoon; to late to try out. Will put it through some tests tomorrow.
Just make sure you have charged both beez completele and that you use them all the way down before you do your second charge.
And remember. The most juice is coming out after several complete charges.
Sent using Arbtalk Mobile App
  • Replies 39
So far already out lasted 1st saw. Small beech reduction and some cross cutting in garden before putting it through some real work next week. Did 3 chgs, didn't time them but seemed to pass pretty quick. Will take a bit of getting used to. Will post again after some on-site usage.
The saw was sent back to Husqvarna and if I hear what the cause was I will post result. NB, from operators manual; "Lithium-ion batteries can be charged whatever their charge level. The charging process can be cancelled or started whatever the battery's charge level."
I have the husky Li xp on trial,now I've been a naughty boy & put a fully charged battery in the freezer for 24hrs!
Thats cold!,hooked it out,& for 20 mins or so it flashed the red battery light when I pressed the charge indicator button,but sorted itself out & held the full charge through the ordeal.
Overall I an impressed with the little saw!
