You say the ancient ash look lovely in the summer so they must be getting enough lite to have survived this long . We need resistant ash for obvious reasons What about felling enough Douglass to help the ash and if they seem resistant harvest the keys for future stock ?
  • Replies 20
Is I've taken on the management of a 350acre mixed wood. Up on the far side there is a huge amount of Douglas fir letting in no light to the forest floor. Hidden away in this mess there are 17 ancient ash. Beautiful they are. And in summer I expect look fantastic. So I suggested to the client that remove a lot of the Douglas fir so these ash can have a better life. And the layout would create a beautiful spot up there!!! But the client says get rid of the ash and keep the Douglas! :thumbdown:
Fell the lot and get the loot in, otherwise you're just pussyfooting about,
if its a ancient woodland with hazel.ash and other trees then the douglas are not doing the wood much good. he could make money by felling firs. have a coppicer renting the wood to make hazel products. if you want to keep the dormice you need to coppice it for its products so it is coppiced on a rotational basis not all at same time so there is wood to use again in 7 years time.
now i am not a expert but the droppings from the firs are not going to do the ph of the wood a lot of good. plus bonus if firs go and light comes back in bluebells in spring.
If you go in too heavy on the DF, then don't be too suprised if large areas blow over in the next gale. Halo thin around the ash might be a better option. Are the DF of good millable quality, or bendy pole of plop ? Also if the ground is damp then there is a good chance of but rot in most of the trees, that will severly reduce their value.
Sent using Arbtalk Mobile App
