Evening All,
I am having some trouble with the in feed rollers it seems to not be gripping the timber properly the top roller just wants to bounce on anything over 2 inch diameter. Also struggles with some of the smaller bits. It's got a new set of blades in it so that part should be fine.
Any ideas any one ?:confused1::confused1:
Hi all,
Thanks for your help with this. I have turned the anvil and checked the springs I have also put a fresh edge on the in feed rollers.
But still no luck it's still not pulling anything through
Any other ideas?
Thanks
check the roller box floor just behide the bottom feed roller and just infront of the anvil have had in the past were thay have worn and the anvil sits slightly pround and catches timber on the way in. if it is worn build it up with weld
