we have decided we need a proper pro saw with a 18 to 20 inch bar have big girl but need one for cutting smaller timber.our big husky is so fast and so quiet compared to our little echo and fed up with echo. use it as a back up.
any recommendations from this stable. do not want a sthil.
560xp with a 18 or i have an 18 inch bar for my 576xp with flies through the wood..
if its smaller saw you want the 560xp is the kiddy...
we did have a look on forest and arb and engine size weight bar length that one was the one that looked like it will do job thank you for your advice will go down to forest and arb and get one
hi we want a third saw with the right bar for cutting smaller wood we have fallers we can cut up to a point then need the bigger saw plus always good to have a back up in case you need it. and echo is good but it is such a dog to get running smoothly tried the jets but not much joy so we have said when we have some cash buy a new saw and echo can be a back up. and the big husky has made us decide its a husky again.
