Afternoon,
Ive got my cs38 coming up next week and have had to order pretty much all new gear (typical it all met its 5 year mark back in september), included in my new set up was Yale fire 13mm rope.
Ive taken the new gear out half a dozen times now just to get used to it and get some practise in and am having a massive problem with the friction hitch sticking. Particularly once Ive started descending. This morning I descended about 4 meters (very slowly) and it totally locked up to the point I had to use the other end of the rope to get the weight off to free it up.
This has happened with and without a cambium saver.
The last rope I had was a cheap yale and I never had any issues with this, even when it was new.
Im using a standard 4 wrap prusik loop. The prusik is marlow 9mm.
Anyone offer any advice on what to try next. I was going to try a different hitch but would really like to stick with what I know.
Cheers
Rob
  • Replies 37
With the same rope different prussik cords can give totally different results.
I spliced 4 different ones recently. On the same rope, one locked up so much I couldn't move whilst others were ok. Finally found the best.
Just experiment on this rope with different prussik cords. works for me but can't advise on what will work for you.
Yea I had a feeling that was going to be the case. Might order some yale silver streak and see how that gets on.
Was going to try a hitchclimber with vt but dont think a week before my course starts is a good time to change systems.
Cheers
Rob
I was going to try an extra wrap but thought it would provide extra friction. Will go and try it again tomorrow and see how much difference it makes before I order some different prusiks.
Thanks for the replies
Rob
it will add extra friction, but it will also spread the load...thats the issue you're really having, not friction.
I suggest after your course experimenting with better hitches also. There really is no good reason for anyone to still be climbing on a prussik this day and age!
