Hi everyone, i have a rayco rg20 and it needs new bearings either side of the cutting wheel, im just wondering if anyone knows what bearings they are - make/model as i want to order two new ones. i have even rung orange plant and they dont know!!:confused1:
many thanks!!!
I had the same problem with my RG13 grinder and Husky wanted a small fortune as usual. Take them to your nearest bearings/engineering dealer they will measure them up and know exactly what you want.
Just go to the nearest bearing shop there standard bearings nothing special and main dealers will want a small fortune.
Sent from my GT-I9300 using Tapatalk 2
westcom equipment/machinery are the main dealer for rayco but they are a standed metrick fitting and most good agricultural surpliers will stock the size you want, just pull 1 off and take it with you for a sizing but you will need a good set of pullers to remove them. You sorted your truck dilemer out yet ham?
Have a good christmas and new year bud if i dont get to catch up with you before.
many thanks!!!
if you can see the bearings and there is a number stamped on them type the number in ebay and theres usually loads of bearings come up
