Problem with stove - help please!
  • Replies 35
Has the stove been lit regularly, or left cold for a few days? You can often get a "cold plug" sitting in the chimney if it's been out for a while. One of our chimneys suffers from it - though not the one right next to it for some reason! I'd suggest lifting the baffle plate out, and lighting a scrunched up sheet of newspaper and holding it under the flue outlet - this should put enough heat into the chimney to get the plug moving then assuming the chimney is in fact clear, you should be good to go. Put the baffle plate back in though! Also when starting it - use a good bit of paper and kindling which will produce a good bit of heat without much smoke to get the draught established in the chimney.
Haven't used it since last weekend so that could be the problem.Will have a look getting the baffle out tomorrow. Cheers :thumbup1:
get yourself a baffle to put on top of chimmney this should stop back drafts when wind is in a certain direction also helps with the draw from fire up chimney. also when you light it are all the vents open to make a draft.
i use newspaper about 4 balls then put kindling wood on top and light it and let it roar. then put on logs. i have also found my logs are under cover but with so much damp they are not bone dry so bringing in more and dry them by woodburner.
