  • Replies 35
That's right black go's in number3 terminal which is earth.
Terminal 3 on what?
Its a trailer, 12N wiring black should go to pin7 which is LH tail light. In 12N earth is White and goes to pin 3
Yes on a 12N Plug white is earth pin3 but there was no white wire so I said the Black may be earth as it turned out it was, so that go's in pin3 instead of the white wire which was not there.(so how could he put the white wire in pin3).
Rover could save himself the time and effort and just update the wiring by buying new..... The amount of time it takes to try and test it all.
Plus in a years time when it goes wrong again he will be scratching his head trying to remember all the colours again.
IMO
It's a standard 7 pin plug
But you told him to suck it and see, thats what the issue is not colours
At no point did I tell him to suck it and see.
Get a battery and put black on - THEN test others on+ and wire in to plug. Look at bulb end to find out colours?
