Chaps, I have a query! At what size do you classify regeneration/sapling a tree. I would have thought at 200mm as CS31 is 200 - 380. I could do with knowing if there is anything where it officially states it, or do you you agree with CS31 as a guide??
Feathered Trees. Feathered trees have a defined upright central leader and a stem with evenly distributed lateral branching over most of its height. Feathered trees can range in height from relatively small plants of 1.5-2m high (2/3 year plants) to semi-mature. Hope that helps. But others may say different .
Interesting 'conundrum' you post.
Just to give another angle/consideration the TCPA (Town & Country PLanning Act) covering trees in Conservation Areas starts at 75mm dia. @ 1.5m above ground level.
Interestingly it alos defines a tree as anything and ordinary person might call a tree...or words to that effect.
I don't believe there is any right / wrong / definitive answer to your question...but interesting nonetheless.
Cheers..
Paul
Above ~ 4-5" (10-12.5cm) dbh. Of course it was a tree all along, but it's no longer a sapling above that size. Slightly moot point though - when does a child become an adult?
out here they say anything with 40cm dbh is counted a 'tree' and need papers befor felling.
i'd say if you cant climb it, it aint a tree yet.
The reason I'm asking is with reference to AFAG 804, Electricity at work: Forestry and arboriculture. Do not fell a tree within 2 tree lengths of energised power lines. My argument is if the "tree" is only 4" in diameter and say 7ft tall, I wouldn't class it as a tree and therefore if it was 14ft from an energised power line it should be exempt??
Think you need to decide what the reason is for the two tree lengths rule, is it to allow for errors in judgement about the height of a tree when felling? Or is it to avoid flashover from power lines?
