Changing MS361 from 3/8 to .325
Jonny Burch
I've been running my old 56cc dolmar with a 9 x 325 sprocket and an old 15" Husqvarna pixel bar.Yes its fast but its cutting a narrow kerf.
If I was all Stihl like you are I would keep to the 3/8" by 63 gauge and run a 15" bar with a 8 x 3/8" rim that would be compatible with your other saws.
Why? Need it explained to me the reasons for "down-gearing" ????
Changing from 3/8 to .325 is not "down gearing " . It just gives you more cutters for a given bar length. Standard rim sprocket is I think 7 pin . you can raise the gearing to an 8 pin but be sure that it still allows the saw to "rev out " . If it does not you stand a chance of plug fouling as it will tend to be slightly rich . You can get away with taller gear ( 8 instead of 7 pin ) if you use a relatively short bar or the saw is ported . ( see spud for porting ! ):thumbup:
