  • Replies 839
I've got the large pinto spacer on mine now and using volcano cord, it's working like a dream 😀
What hitch and length of cord have you got with that. I want to get some volcano soon.
The volcano movement has begun it's good stuff eh?
how do you find the movement with the spacer , comparable to a pulley?
...how do you find the movement with the spacer , comparable to a pulley?
I have tried many different size and shapes of rollers and sheaves and though they do make things smoother, they don't do the same thing that a pulley will. A pulley not only reduces tailing effort but also keeps the HH straight and inline while doing so. That improves consistency and reduces setback.
A trick that I have mentioned before, is to gently squeeze the end of a fixed pulley untill you get the opening small enough that it is a press fit onto the bridge ring. When done right it makes putting on and taking off the pulley much easier.
I just bought 1m and use the standard HH hitch 👍
The volcano movement has begun í*½í± it's good stuff eh?
It's not quite as smooth as a pulley but plenty smooth enough. The main thing is that once it's on you don't have to think about it again. I found with the pinto it was a pain taking it on and off whenever necessary. I think the new cord helps loads too 👍
If I was making a HH I would make the plates a tiny bit bigger so a special pulley could be put on with a slick pin, it'd just need a hole between the bottom slot and the edge. You could even slot the hole a little so the pulley moved in time with the karabiner?
