Has anyone used recycled plastic sheeting for a plant trailer bed. (such as stokboard or eco sheet)
Got a small plant trailer - only used occasionally for transporting a stumpgrinder but the bed is rotten and needs replacing.
what are the options for materials?
The recycled boards have no strength when warm. The proper stuff is called phenolic board or something if you do a search I think I got some from silverman. Not cheap but looks the bus and lasts 15-20 years.
I wish, there isn't much that lasts 15-20 in arb without showing its age, I have put a new bed in my IFOR twice in 6 years and its ready for another, I do make it work for a living though.
Phenolic is still the best option I know of though
steel checker plate over ply is the best flooring for trailers i think, will last for years and takes more abuse than phonolic in my opinion
Would Ally checker plate not be better? Just as tough and loads lighter.
I replaced by 8x4 plant trailer floor with a ply sheet, lasted about 6 months before it started splitting into layers, then eventually broke when i loaded my mini digger onto it. So im in the same boat as you, i thought about eco sheeting but doesn't look particularly convincing if you load heavy plant onto it.
Trouble is the Ifor 8x4 trailer requires a sheet an inch or so wider then the standard sheets to fit properly, standard sheet still works but looks a bit sloppy!
I used to use Ally chequer plate. I seem to remember that it 2500x1250 rather than 8'x4', so was a bit larger.
