  • Replies 217
Bad luck about the wall! if a job is tight on money something like that will rip the fun out of it. Ringing it down will be a PITA, maybe that crane might of been a good idea after all!
I had plenty of money on the Job ie 24 but yeah this Job was def not about the money
A tough quote all round but a massive learning curve
Sent from my iPhone using Tapatalk
[quote name=David Humphries;768340
Putting the potential basal issue aside' date=' I believe there would of been scope to manage this tree in this situation by reducing the sail volume and size.
.[/quote]
Interesting comment, how much of the sail volume and size do you estimate having to remove to achieve this David?
To be honest Jonny, I wouldn't know that without assessing the trees structural condition & exposure within in its environment.
Thats quite understandable, however, during the assessment, if it was found that the residual wall is less than the established amount, a vast portion of the live crown would have to be removed.
It is true that any tree, regardless of the thickness to wall ratio can be retained, unfortunately, if the residual wall gets too thin then what we would be left with after our reduction is nothing more than a pole smothered with epicormic growth, looking more like an over-sized toilet brush as opposed to a tree.
The professional tree inspection workbook tells us that if a defect apears to be a cause for concern " it must be measured and the SRENGTH of the remaining part evaluated"
I just wondered that before all this information is collected and understood, how could a decision to retain and manage the tree be made?
Climbing inspection with access to resistograph and/or hammer/probes, would be my way of evaluating the possibility of retention of a canopy with dysfunction.
A perfectly acceptable and well recognised approach and the key word "possibility" of retention
Please excuse me for being a pedantic b*****d David but these are all relevant
Points when dealing with something of this size in this particular location
Kindest Regards
J
