Looking for someone to install flue etc, I have all materials (burner, flue etc. so just need an installer to do flashing etc and attach to brick work. Can anyone recommend anyone in lancs or on here who does them.
Recommend you use a HETAS registered installer. If not make sure you get it signed off as safe to use by a building inspector or you will be open to prosecution for breech of building regs. I usually advise that in the case of a fire your insurance would also be invalid but someone pointed out earlier this week that this may not be the case.
Β
A
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
