I think that was manufactured by the Kane Engineering company that make most of the big agric trailers we see around these parts. Haven't seen one of those about for a while. There used to be loads around in "Kane" blue. Very solid bit of kit and the best thing about them was they are built to an agricultural spec and can be fixed and worked on in any workshop with a box of spanners and a good welder. You won't go far wrong although the price is a little high unless there is a warranty with it. Last one I saw going through an auction in Belfast was about £1500-2000 mark although it wasn't running right.
Looks remarkably like an agribuggy 2d which is a small self propelled sprayer/ fertiliser spreading machine. It has a lot of attatchment points on the chassis for all sorts. Ours has a ford duratec engine and gearbox transfer box for 4wd and landrover axles. The diff is geared down, 24mph with small lgp tyres on as fast as you dare with 36 inch rowcrops on
