ash and birch burn them green or burn them old. keep your chimney/flue clean ,1 cm seasoned beech at 60 pounds delivered and stacked ridiculosly cheap, time for reality
Beech wood fires are bright and clear
If the logs are kept a year,
Chestnut's only good they say,
If for logs 'tis laid away.
Make a fire of Elder tree,
Death within your house will be;
But ash new or ash old,
Is fit for a queen with crown of gold
Birch and fir logs burn too fast
Blaze up bright and do not last,
it is by the Irish said
Hawthorn bakes the sweetest bread.
Elm wood burns like churchyard mould,
E'en the very flames are cold
But ash green or ash brown
Is fit for a queen with golden crown
Poplar gives a bitter smoke,
Fills your eyes and makes you choke,
Apple wood will scent your room
Pear wood smells like flowers in bloom
Oaken logs, if dry and old
keep away the winter's cold
But ash wet or ash dry
a king shall warm his slippers by.
Welly boots will stink and smoke,
Pallet wrap your flu will choke
But tyres treaded or tyres bald
Will keep away the winter's cold.
Burning tapes and DVDs,
Will cause your ecofan to seize.
A gallon of petrol in the grate,
Will put you in a terrible state.
But tyres white or tyres black,
Will warm your aching back.
Plastic bottles, tubs and spoons
Your neighbours will complain of fumes
But tyres old and tyres new
Will finish them off with acrid plumes.
I prefer beech and nothing goes on my fire unless its seasoned for a year if not two. That poem needs binning. Wood seasons quicker when cut to logs rather than left in cord. Beech seasons fairly well in cord lengths especially if the harvester has marked the sides. In my experience ash will be dry as it was cut down.
Stereo's poem is more accurate and factual and should replace the other one.:001_smile: perhaps it could be extended to include roof felt, railway sleepers green flames and tantalised timber. :biggrin:
An epic poem, great work stereo
