Strong Chainsaw lanyards?
Samuel
  • Replies 22
are there any stronger chainsaw lanyards than the stein ones? as i have been looking and can only find the stein ones?
thanks in advance
The husky one is by far the better strop out there, we supply them all and yhis is the best, the Weaver is great but seems abit too tight when you pull on it. The Husky ones is the priciest of the lot although it does come with a harness bag to put your pulleys, slings...ciggies in..
Husqvarna Chainsaw Strop
Splice your own !!!
Could you explain your answer?
Splice from ?
Saw lanyards have to have a low breaking strength for safety reasons. It needs to be able to break, not long ago a climber was killed through using something with a to high swl and he was pulled out the tree along with his anchor point when his saw was trapped in a limb he had cut off....
