  • 5 years later...
13 hours ago, Dbikeguy said:
what friction knot do you use with a tether that short?
The tether when clipped into a hitch climber and the hitch itself secured to the bottom carabiner works out the same length as a normal tether. I use a Distel though. It allows you to swap from SRT to DRT without coming off the system.
Edited by Guest
i need to try that hitch... using a VT at the mo and even with extra wraps it’s almost touching the wrench when sat back. just had some cord arrive to experiment with cord length too.
I’m about to begin sea trials with a knut after wrangling with that problem for a while. Has been working fine dangling from the loft hatch.
