Hey folks, any of you guys using capstan winches to aid splicing?
if so what you using, lets see how you have it set up :)
i use a pair of 2:1 petzl Twin Pulley - P65
i use a 5:1 ISC rescue hauler atytached to a super strong bungee loop where its anchored so as i smooth tthe cover to send it home it keeps quite a bit of presure on
no, im not sure why i would need to
its for certain splices on certian ropes with very tight braids & maybe very long burys, allot of profesional riggers use them, sometimes on splicing instruction videos you see a cut to: and here it is!! sneeky swines :sneaky2: you try enmulating the marlow gecko/aeris splice method without one you'll soon see!
i was of the undertanding that marlow removed very little when constructing their splices so brute force was needed to bury them
as above
its all a bit of 2 and frowwing, if its jammed, wooden mallet, then back on rig.
sometimes its easy, sometimes not.
as above
jamming is generally as a result of dirty rope, or not being 100% carefull with your fids imo
