I already have Heavy duty springs and helpers, Bilstine has struts but I do get a bit of body roll so I have put the Extreme 4x4 anti roll bar on to replace the standard one and its a heck of a lot thicker. I'm just puzzled as to how the drop links should go.
HI HODGE HERES bump thanks jon :thumbup:
Yeh, was just the pics I thought may be helpful.
I'm looking into the same at moment with one of mine. I'm not sure I can run to £230 just for a bit if round bar though!
I do have an old scrap disco with standard front and rear bars I could rob, they maybe not as good but will be free!😉
HI 18 SAVES you £230 plus like you say fit a disco one with new rubbers thanks jon :thumbup:
Mine had standard bar on the rear but as I have a box tipper it can roll a bit, this should be better now.
They aren't expensive hodge. I've got them on both mine, one with on board control and pump, the other just an external valve to blow up with a compressor.
I'd not bother with the extra on board stuff again.
The bags are usually connected with a common "pump up" line, but if you don't bother with on board stuff you can fit a valve for each bag. This will massively reduce roll when loaded as if they're connected, the air rushes from one bag to the other when cornering, in fact, making roll worse as the pressure will always be equal at both sides.
Hope that all makes sense. 😎
Drop links go down same as in the extreme 4x4 pics on mine.
I tried air bags on mine but they were a crap fit on new springs, they couldn't fill the full length, would work ok on worn out springs I guess.
I probably need to look into it again though as my hard suspension is killing both my back and the truck.
