  • Replies 54
You don't need a piston stop and you don't need to hit anything..... Oh and you don't need " the tool " :biggrin:
You come undo the clutch on my 090, tools are a must
Sent using Arbtalk Mobile App
I said for doing it up you don't need a tool
Just spin it on by hand and the next time you apply the chain brake it tightens . How I have always done it anyway .
I used to do that. Last time I did it, I had to order the replacement part from the US. You'd be amazed how far a clutch can jettison when you have a plastic clutch cover.
I suppose you haven't heard about wedges? :biggrin:
I haven't had to use a wedge to buck wood since I was 19. That was back when Reagan was president and you were about to retire. ;)
I use them for undoing clutches, only do em hand tight when they go back on, they tighten themselves, especially if I'm testing the saw
Well that is exactly what I said in my post a little way back ....:001_smile:
Yeah, but I wouldn't remove one with a screwdriver, I've done that once, ripped the clutch apart!
I only use huskys now and on , say , a 346 which is a spin on - spin off clutch I have an aluminium drift which I give the clutch a tonk and it spins off . Compression is enough ( pull out the de comp button ) . When you spin it back on finger tight , rev the saw , sap the brake on and Bobs yer uncle and Fannys yer aunt .
About the same as having the clutch come off when firing a saw up without the clutch cover being on I should think:blushing:
