This quote is a bit flawed as if someone had two load bearing anchor points then the bridge is always going to be a single point of failure unless your close to the stem and using side ds
Sure, but if your lanyard is connected to the side D's you won't have a single point of failure in the system. So moving from that configuration, you reduce the inherent protection in the system.
  • Replies 37
Yeah i get what you mean but not all side ds are rated to be hung from so if your in a position where your tied in twice but on the front d then its a single point. This is a reason i want to try the treemotion as you can hang from the side d
I'm with Ben. I think it's the same with all bridge type harnesses. The treemotions' use of a rope just makes it seem less able to deal with a bit of unintentional Silky action....
If worried about cutting the bridge and the bridge failing, then why not do what is often done in climbing with a back up tied through leg loop and waist belt?
I've been doing that for years, never had a problem.
:dito:
Since its for getting a good working position it makes sense to clip it wherever gets you that good working position.:thumbup1:
Sometimes I think you fellas worry about stuff too much!
Can you explain this a bit more please mate?
:dito:
Indeed, its not like its ever going to get shock loaded.
